1001001
I'm considering applying truck bed liner material (paint-on kind, either spray or brush) to my floor pans (front and rear) in my RV-10 to help protect the floor and prevent any moisture that might get in the carpet--from snowy or wet shoes--from contributing to corrosion.
Also, the liner material should be tough enough to resist abrasion over the years.
My floor pans are already primed with S/W epoxy strontium chromate primer.
Anyone have experience and/or other thoughts about this? If you have done this, what products did you use and how did you apply them?
