B bobnoffs Well Known Member Jan 15, 2022 #1 hi all, does anyone know of a supplier of just needle rollers? i would buy either a stock dimension or order a custom size. thanks for any help.
dpansier Well Known Member Jan 15, 2022 #2 I have used Dowel Pins in custom size, low speed applications, McMaster has a wide selection.
H harleyl Active Member Jan 16, 2022 #4 Loose needle rollers If you want the needle bearings without a cage you can search for “loose needle rollers”.
B bobnoffs Well Known Member Jan 16, 2022 #5 yes, i think they are available somewhere, i am going to have to talk to someone at timken etc. this is for an evinrude outboard. i am following another lead that the needles are still available for a lawnboy lawn mower!
BillL Well Known Member Jan 16, 2022 #6 They used to be made by Torrington, Bob. My information is 30 yrs old. Edit: OK, maybe 50 yrs old. What diameter/length do you need?? Lily Bearing might have a listing. Last edited: Jan 16, 2022
