czechsix
I received the parts for the replacement inboard aileron bracket today (decided to go ahead and do the mod now before riveting on the bottom skins). In the old bracket the bearing was a press fit, but with the new bracket the bearing has some noticeable free play...the machined recess in each half of the bracket is perhaps a couple hundredths of an inch larger than the outside diameter of the bearing. You can just drop the bearing in and actually slide it around a bit. Has anyone else found the same thing with your SB 16-03-28 parts?
My concern is that if there's even the slightest amount of movement of the bearing housing vs the aluminum bracket, it's eventually going to cause wear that will require replacement of the bracket and bearing. It will probably be less prone to movement after the two halves of the bracket are riveted together, but since there aren't rivets all the way around the circumference of the bearing I'm not confident that the clamping force will be sufficient to guarantee no movement will occur under the cyclical loads that it will experience with aileron movement. A good interference fit like the original design would make me feel a whole lot better...
