[email protected]
I'm New Here
Hi all,
Long story short, I have a lovely RV6, 0-320 wood prop, the CG is too far aft for max utility. I’ve got a 10 lb crush plate coming.
Don’t really want to change props, mine is a performance propellers work of art, it’s beautiful.
Question...has anybody tried mounting a pc 680 size battery up by the starter alternator? I think I have room there, my accessories are small lightweight ones.
I figure moving the battery up there, would move my cg forward plus add lightness over the tractor battery further back on the floor.
Heat and vibration - killers? Has anybody tried this?
I did search, didn’t find anything.
Boyd
I’m switching out the Sensenich metal prop on my RV-6 0-320 for a Wirlwind ground adjustable prop, i’m also interested in moving a PC-180 as far forward as possible to compensate for the 18 lbs lighter prop.
Hard to see how you could build a rigid mount up there. Batteries are intolerant of vibration and not sure I would want it rigidly mounted to the engine. I put mine on the firewall, but doubt the few inches gained helped a lot. I just gave in and used a 20# crush plate, which gave me decent baggage capacity. An old starter will add 10 #'s as well.
Larry
Larry
What Larry said about vibration and rigidity mounted to the engine.
I have seen a number of RV-6(A), -7(A), & -9A that had batteries mounted on the front side of the Firewall. Not just the PC-680 but the full size Concord battery. Not sure how much that helps move the CG forward but if could be 8 to 12" forward of the floor mount RV-6(A) battery that was in the plans 20+ years ago.
Wheelchair battery
I use a 35ah AGM wheelchair battery on the cabin side of the firewall in my 6A. It's heavier than the new batteries, but that may be a good option. When I changed my prop from a Sensi metal to a Sensi ground adjustable my CG was still well forward so that I could load up my baggage area when the wife and I travel. And, that's with an 0320.
I just bought a new battery for $100 at Batteries&bulbs+. I can tell you from experience that 35ahs will keep your radios going for quite a while if your alternator quits.
Another helpful move was to install an Antisplat Easy Exit Bar. It doesn't weigh much, but it gave me a good place to store my heavy tool kit on the front side of the wing spar. And the device makes exiting the plane way easier.
John
legacy Lycoming starter
What about a legacy heavy-weight Lycoming starter? I don't know how well they work but I think they are heavy.
I used one of those for years, but the performance was so-so. I’m much happier now that I have a lightweight starter which spins the prop better and a flywheel weight to help with the CG.
How would you match drill that spring to fit a legacy (field drilled) mount?
Remove your steel tailspring and send it to us so that the three hole locations - the one that holds it in the tailspring mount plus the two that hold the tailwheel pivot onto the spring -can be duplicated in the titanium replacement tailspring.
