czechsix
I have an original Dynon D10 (not the D10A) that I use as a standby instrument and recently decided to add the internal battery. I purchased the battery and upon installing it found that there's not enough room between the end of the battery and the cover. The battery itself fits completely inside but there's not enough room for the mating connector, and I can't see any way to tuck it out of the way, so it prevents the cover from fully closing. I've checked several times and I'm sure the battery won't go in any further (there's a standoff on the circuit board at the end of the battery compartment and it's making contact with that).
Short of cutting off the connector and soldering on the leads, does anyone have any suggestions? Dynon claimed it would fit the D10, so I'm wondering if my D10 is an anomaly or if others have had this problem in the past.
Mark Navratil
RV-8A N2D
Spring Hill, KS
Mark Navratil
RV-8A N2D
Spring Hill, KS
