Av8rRob
I am going to use a multi use battery box from earthx. This box will fit the earthx batteries and the traditional odyessy (if my weight and balance forces me to). This box is different from the kit one in that the mounting flanges bend outward rather than inward. Therefore it is a bit wider than the Vans box. Seeing what is on your firewall, would you recommend I mount it left or right of the intended location 1/2-1 inch mind you?
