1949MGTC
Active Member
Sponsor
What tools and tips do you have to countersink the battery box? I don’t want to scrap it! Any help is appreciated.
Bill Gardner
140849
You might have to countersink them free hand as there are some that a countersink cage won't fit. I use an extension on my cutter and just go slowly. Keep trying a rivet until the required depth is reached. Once you have one cut properly you can judge the next one by size of hole until you get very close.
Better to dimple rather than countersink. I assume you want the flush rivets to be smooth on the inside of the box.
You need a bench vice, a 2x4, #10 drill bit, male die set, place the male die in the hole you drilled in the 2x4 which is clamped in the vice.
You need something that you can hold the female die against the work piece while you hit & form the dimple with a hammer, (possibly the striker rod from your C-channel)
Probably some extra hands would help to stabilize everything.
Now you are set up for your 2 minute task! Dimple away
