Seems the newer kits don't require as much heavy metal cutting.
Yeah, but a 6" notcher is even cleaner! Like butter.If you are using a band saw to cut stiffeners you are wasting hours and hours of time. Stiffeners are easily cut with old fashioned tin snips. Do not use the short aviation style, the longer the blade the easier the job. A bandsaw will leave a rough edge that takes extra work to smooth. After a good cut with sharp tin snips a light touch of the scotch brute wheel is all it takes.
I like band saws, I have two of them, mainly for woodworking. They got little to no use on the 14.
