If you want it to fit tight and flat what you do is lock the door down then pull rivet as many holes as you can from inside the fuselage. Impossible if you have the rudder peds in unless you are long armed. That will set the shape. Then after a bunch of rivets are pulled, get out ( if you can) and pull the remainder. Good luck, Bill of Georgia RV-8a
