I'm already baffled by the baffle plans. At the very beginning, on page OP44-3, Step 3 says "Position the CB-705B Oil Cooler Brace on the CB-705A Cylinder 4 Aft Baffle per plans page OP-27A....".
On Page OP-27A, they don't actually give you dimensions. They don't tell you where exactly the FF-709 sits, so you don't even know where to cut that big hole. Note 3 on the drawing says that you should "fit cowling and rubber air seal material in this area prior to mounting the oil cooler. For the greatest efficiency mount the oil cooler as high as possible".
We have chicken and egg scenario here. This is the first assembly in the baffle plans, so I can hardly do what Note 3 asks of me. But without having done that, I have no reference for positioning the CB-705B Oil Cooler Brace.
What the heck?
What the heck?
