TCONROY
I'm fitting the rubber baffle seal to the baffles and came across an issue. Where the oil cooler brace would normally go, I have some angles in the baffle I'm not sure how to properly seal. Here is what I've done and I *think* it will work
I'm looking for suggestions on sealing that corner area.
For those wondering why I didn't install the oil cooler brace, Van's recommended not using it since I've mounted the cooler to the firewall.
