BillL
IO-360 and Vans latest baffle kit (early 2014). I know nothing about fitting baffles and VAF is my best resource. Please look below and give me some guidance. Thanks,
The screw is into the case, so the baffle is tight against the case, the center is held against the angle for reference. The gap results from a non planar contact with the case, although more trimming can not be done without losing the attachment at the noted screw.
This is with the center brace in place, and there is still a gap on the left side also. Surely I can pull the back in alignment with the plenum cover, but is this how these things fit? What am I missing here?
