Harder than AD rivets
Hi Claudio
Sorry about the slow response I've been crook..
The D rivet is a little harder than an AD rivet, I don't have the material spec to compare the two types of rivets, they need just a little bit more of a hit to put them down.
D rivets are normally used in preference to AD rivets for structural assemble. The part number you listed is a 1/8th dia rivet, I'd be careful if you intend to use it on thin material, you can distort the sheet if too much force is used in riveting.
D rivets are easy to put down using conventional riveting techniques, rivet gun, pneumatic squeeze riveters.
Hope that helps,
