Superprohero
Member
Still in the tool acquisition stage. Was looking for some advice on a back riveting plate. After a lot of reading I think I would like to do as much back riveting as possible for a clean flush rivet look. Or is there not much opportunity for that to make a big difference?
Any suggestions on what the preferred thickness of steel plate is for back riveting? Was wanting it to be fairly sizeable to do several rivets in a row but not too heavy to set on and off the bench. Was thinking maybe 4" wide by 2 or 3 feet long but was unsure on thickness needed.
I have a very sturdy rolling metal working bench made of steel that I installed a nice table top onto for the smooth surface and it's pretty darn solid but I'm concerned the rivets will eventually pulverize it.
Thanks for all your advice.
