Just curious on whether anyone has considered mounting any avionics on either the top of the F10405 Forward Tunnel Cover, or mounted to the forward side of the F14106 vertical wiring channel? I was thinking this could be a good location for the GAD27, and some relays (pitot relay, lights relay etc)
I was planning ahead and will likely have my circuit breakers and bus bars (power sources) on the angled 'power module' panel. Having the GAD27 and the relays close to the power source would mean not having to run 18AWG wires up to the panel switches etc - i can just run small 22 AWG for grounding (and i have a much wider choice of switches).
