I get the fact we didn't provide you with much of a spreadsheet!
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
That said, here are a quick few really rough numbers that you can use real rough "guesstimates" in your search:
1) Single screen EFIS system: $5K
2) Dual/Triple Screen EFIS system: $10K
3) Dual Axis Autopilot Servos: $1700
4) Stand alone A/P controller: $800
4) Engine probes/sensors: $1000
5) Comm Radio: $1200
6) IFR Certified GPS/NAV/Comm: $9800
7) Heated Pitot: $300-450
8) Audio Panel: $900-1500
9) Transponder: $2200
10) ADSB receiver: $700-900
Rough VFR pricing for core equipment: around $12-16K
Rough IFR pricing for core equipment: around $22-30K
Now all you have to do is pick the brand, because most of the popular systems will fit into the above model (AFS, Dynon, Garmin or GRT).
Of course people can point out variables up and down, more and less, as well as a whole multitude of things that can change that either direction on any given brand, but those are good basic ROM numbers. Honestly, it's of little value to produce a spreadsheet that simply ticks off the same basic check marks with almost equal resultant prices across the several different brands...that's won't help you make a decision at all. What will, is the subjective parts everyone has discussed. The core things are just literally about the same prices across vendors. Everyone sells servos for around $800. Everyone sells probes/sensors for around $1K (for 4cyl). Everyone sells a transponder for around $2200...so on and so forth. People will likely point out that on the low end you can spend a little less and on the high end you can spend a lot more, but for the typical real world use the above numbers are typical "averages".
My point in the end is once you figure out that all the systems cost about the same amount (almost within dozens of dollars of each other across equivalent systems), you just need to figure out what level of equipment you're looking at then you'll be good to go!
Stein
PS, you'll love your smoke system!
