Dan92
For those of you that have a U3 Smart Drive, there is a small aircraft weight and balance program that is available, and the best part is it's free. According to AvInfo it: Provides the ability to display weight and balance for small aircraft carrying up to 6 people with a single fuel arm and up to 2 baggage areas. You can define your own aircraft specific limits and store named passengers.
Sys Req: U3 Smart Drive (a USB flash drive), MS Win 2000 & XP, printer
(optional)
When you set up the U3 Smart Drive, go to *Add Programs then *U3 Download Central and then U3 Utilities. You will find AvInfo toward the bottom of the list.
Here is what the website for U3 says:
"Meet the next generation of USB flash drives: the U3 smart drive. It's
what's inside that makes them smart.
Carry and access your files easily
Keep your data safe and secure
Comes with pre-loaded software
Hundreds of software titles available"
I set it up for another aircraft I own and it seems to work well, plus you can take the Smart Drive with you and plug it into any computer.
Dan
