Sunglasses (long reply)
otterhunter2 said:
Make sure your sunglasses are of the non-polarized version. Apparently you will have problems viewing LCD displays if you have polarized sunglasses. New info to me! But on reflection, it makes sense!! Never flown a glass cockpit. Link from Dynon on this subject.
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1154041174
LOL
This is true, but not quite as big a deal as is often stated. Reflected light off of a plane surface (like water) is partially polarized, so a polarizing filter oriented 90 degrees away can block much of the reflected light, but let other light through. This is why most high-quality sunglasses available now are polarized--they cut glare from horizontal surfaces like water.
In airplanes, there's less benefit and some disadvantages. It may be harder to spot traffic (harder to see sun glinting off shiny surfaces) and harder to read LCD displays, which polarize light themselves.
Most manufacturers of LCD-equipped cockpit eqipment realize the potential problem, and orient the displays so that they are readable through polarized sunglasses. I have a lot of hours flying behind a BMA EFIS/one, Garmin 430/396, and Avidyne Entegra with polarized glasses, and haven't had a problem. Some LCD devices that can be turned 90 degrees (like the older Garmin Pilot III) were completely useless in one orientation or another.
I sell sunglasses, so I have more pairs than would be strictly necessary, and I get to try out a lot of different ones. Although I would prefer non-polarized glasses for most flying, it's hard for me to find the other features I want, and I nearly always wind up with polarized glasses on. In my unpainted (for now) RV-8 the wings can make a very effective solar oven on some headings, and the polarization really helps with the glare.
More important considerations for me are comfort, and how the glasses interact with the headset seal. I like the Oakleys, but the temples are so thick that they render my headsets useless. I prefer frames with really thin temples that fit under the earseals, or that will comfortably ride on top of the earcups. My all-around favorites for comfort, cost-effectiveness, and function are
these. Similar frames are available from half-dozen manufacturers.
In-the-ear headsets like
quiet technology can broaden your choices. I'm using these with custom earmolds right now, and like that I can pretty much wear any hat or sunglasses I want.
James Freeman
I'm an ophthalmologist, but I don't play one on TV...
