HarryL
Active Member
G3X and AV-50000A
Could someone please tell me the weight of the AV-50000A control module?
I'm not using one but need to work out a provisional weight change as part of my UK LAA modification application.
Another question about the function of the PCB for manual trim when the RV12 has G3X and autopilot installed. Does the PCB in the Av50000A still control manual pitch trim speed through a PWM or is this bypassed and trim speed just relies on the G3X speed scheduling system regardless of whether the autopilot is engaged or not?
Harry
