rockitdoc Well Known Member Sponsor Nov 10, 2022 #1 Is it possible to put a gear driven auxiliary alternator on the back of the 390EXP119?
B Bavafa Well Known Member Nov 10, 2022 #2 If you ordered your engine with accessory case, then yes. It would be the same as the non-EXP119
