I Need A Measurement From The Pivot Bolt OUT To The Autopilot Controlrod Attach Point For The 9a Aileron Bellcrank....
The hole distance from the pivot point on the aileron bell crank should be the same distance as on the servo arm piviot to the rod end attachment hole. This is per Trio. They use the same servo.
