jongowdy
I'm New Here
Hi All,
Does anyone know of an approved way to route the wiring for the elevator servo through the spar web on an RV-4?
Thanks in advance.
Jon
Through the Stick cut out
The cutout in the center of the spar for the control stick torque tube has enough space around it for a wire to pass through and be secured on either side. I'm not sure if you are referring to forward or rear spar, but alternatively you can also run them through the fuselage frames by putting small holes just above or below the rudder cable runs, and install grommets. That is the route I used for a smoke system wire and feed line installation to the baggage compartment in my RV-4.
