tx_jayhawk
Anyone find a good way to attach the registration pouch to the classic aero interior panels? I would be interested in seeing people's attachement methods, whether to the interior panels or not.
THanks,
Scott
7A Getting Close
Try Velcro with adhesive backing.
It worked for me. You may have to use a stronger adhesive to hold to the side panel when hot.
Good luck.
David
Good luck.
David
This method has worked for me with no issues wo far. Even in summer time that I leave my canopy cracked open, the airflow or heat has not caused it to come off.
I wish I had a photo of the two pouches in my RV.
I didn't have to attach them with anything.
The pouches are the cheap ACS clear face ones with
the brass grommets.
I'll try to describe and can email photos later if wanted.
They are sitting on the upper longerons with the back end
slid in along the side of the CAD top rear baggage cover.
The front side of the pouch slips behind the curved flange
on my slider 7 and locks them up against the turtle
deck skin. You can reach in from the ground to remove
and reinstall them.
Tom
sticky
I used the industrial velcro, but in the heat and humidity of the summer in the south, it became a sticky mess down the side. So I cleaned all that up, and pop riveted the registration number pouch in with a couple of small tinnerman washers in the grommets on the pouch. Looks good and no more mess.
