Simple for a Side by Side.....
On the 7, which has a firewall recess that is recommended to be installed late as possible, you can use the pattern of rivet holes to attach a pivot.
Materials needed are:
4 short pieces of angle, long enough to cover the 4 sides of the recess.
A short piece of 2x lumber large enough to fill the hole and attach to the angles.
A galvanized base flange with 3/4 NPT hole (this thing has one NPT pipe hole and 4 bolt holes on the perimeter.)
A short piece of 3/4 NPT pipe.
Use cleco's in all the fiewall recess holes and this is plenty strong enough to suspend the front of the fuselage. The system above, simply provides a pivot bar that can be supported in any method you choose.
This system does not put the pivot on the CG line, but I have found this not to be a problem.
Currently, I have my pivot bar sitting on a board in the upper rungs of a sturdy A-frame ladder.
Here's a pic of the firewall BBQ spit.
