I tend to run LOP, and #2 peaks first by a lot. So, injector balancing would help.
But, also, I think prop balancing is in order.
Who does that sort of thing ? Is this a standard A-n-P service or do I need to search out side of my area (Nashville) ?
Not likely to help. A 3-blade prop on a 6-cylinder engine beats like a 2-blade prop on a 4-cylinder engine. That's why 3-blade Catto's run so nicely on O-320's and O-360's, the number of blades isn't an integral multiple of the cylinders.Three blade prop?
What we're recommending is using two J?9613?76 mounts in the rear and two J-7764-31 isolators in the front positions. We performed a 6 degree of freedom dynamic analysis with this mount system and it provides good isolation and should also provide long life.
If you want more info on the Lord mounts contact Sue Cermak [[email protected]] or Paul Snyder [email protected]
For a 6-cylinder engine, you'd need a 4-, or even better a 5-, blade prop to smooth out the prop-to-cylinder ratio. But by that point you're losing a lot of efficiency in your propulsion... Might look cool though...![]()
I suppose I over-stated that a bit... On two otherwise identical setups, three blades will be smoother than two, yes, but you could get even smoother if you increased the blade count so the piston to blade ratio wasn't an integer.I've flown a number of planes and the three blade is always smoother. My three blade MT IO-540 is orders of magnitude smoother than my buddy's two blade Io-540.
Also it helps if Barrett Engines massages the engine first.
My IO-540 and three blade is so smooth that the guys on the airport say they can always tell it's my RV-10 because of the silky sweet smoothness.
I use the Dynavibe balancer and routinely get down to .01-.03 IPS. My RV-10 with a 3 blade MT is at .01 IPS and it is noticeably smoother than 2 blade RV-10's I have flown. So much so that you start to notice other things making noises!
Vic
