Most any 12v LED strip will work. These already have the current limiting resistor wired in. E-Bay is a good option.
Because is said it is made for RV's:
It can be used on motorcycle, ATV, snowmobile, golf cart, go-kart, car, truck, SUV, RV, or anything you can think of.
Kent
I've always thought LED lights needed pulsed width modulation to dim properly, but the Vans offering looks to be a simple variable voltage regulator.
Out of curiosity, of those that have LED lighting with the standard dimmer, do they dim easily and over a large range or is the dimming action very sensitive or "touchy" and abrupt between full bright and dim?
