Italiancowboy
Active Member
On FlyQ and ForeFlight, I can show my plates in “track up” vs standard “track North” mode.
Is it possible to do that on Dynon Skyview or HDX ?
If so, how ?
HDX Pilot’s User Guide
If so, how ?
Many aspects of the moving map's appearance can be configured or modified using the MENU > MAP SETUP menu.
The following section describes the various map features and behaviors that can be adjusted through this menu.
• MAP MODE:
MAP MODE – Use this setting to specify when the map is displayed in “Track Up” vs. “North Up” orientations.
WITH CHART – Use this setting to specify whether the map is displayed in “Track Up” vs. “North Up” orientation on a Geo-referenced chart when enroute charts are being displayed. Some pilots choose to keep this in North Up to preserve chart text legibility.
It says it will only rotate the enroute charts, not approach plates.
Reference: Revision G page 5-33
Brian
