Bad Sheila
Active Member
I have a Dynon d1000 and would like to know how you interpret the color bars for the best glide speed in my RV6
I just finished reading this article shown in the RV-12 forum.
http://www.oshkosh365.org/saarchive/eaa_articles/2001_05_19.pdf
I posted a long reply to this one two days ago, but it isn't here. I must have forgot to hit "Submit Reply". Arggh!
Short answer - you do the same testing you would if you didn't have AOA, but you note the AOA reading at each of the test airspeeds. After the flight you plot the data, and determine the speed for best glide. Then, you refer to your recorded AOA for each speed and figure out what the AOA value is for your best glide speed.
Long answer - do descents in smooth air at a range of airspeeds, over the same block of altitude for each descent. Start a stop watch at the top of the altitude block, and record the time to descent to the bottom of the altitude block. Also record the AOA at each speed. Fly each speed twice, once with the wind off the left wing, and once the other way with the wind off the right wing. After landing, calcuate the rate of descent for each run, and average the values for the two runs at each speed.
Plot rate of descent vs speed. Draw a smooth curve through the test points. Draw a line from zero rate of descent and zero speed that is tangent to the curve. The point where this line touches the curve is the speed for best glide. Refer to your test data of AOA at each speed and figure out what the AOA reading is at best glide speed.
Do the descents at idle if you are looking for best glide speed with the dreaded "engine stuck at idle" failure. If you are more interested in best glide speed after engine failure do the testing with the mixture pulled to OFF. The best glide speeds will be different in these two cases. Prior to doing testing with mixture OFF, do some practice forced landings with engine at idle. Then do a mixture OFF test at altiude and confirm your engine restart procedure. Do the actual testing close to an airfield with a suitably long runway, to cover the extremely unlikely case where you cannot restart the engine.
