CharlieWaffles
I am trying to figure out if I can use the Ray Allen POS-12 to meet my needs. It is not addressed in either the VPX or the AFS EFIS documentation. I know the AOA Flap switch is not needed if you use a position sensor (POS-12). But generally this is connected to the VPX for flap positioning. So can the AFS EFIS read the flap position that way (via the VPX Serial) or can the POS-12 signal lead be connected to both the EFIS and the VPX? If not, I assume I would have to wire up a second POS-12 or flap switch so both VPX and EFIS can handle the flap information properly.
