Master Designs
It's fairly new, but curious if anyone has researched or installed the Dittel KTX2 Mode S Transponder? Looks to have the encoder built in? Pretty small and light. Thoughts?
Note that this is a Class 2 transponder and is not legal for ADS-B OUT after 2020 even if hooked to a compliant GPS.
(b) 1090 MHz ES and UAT Broadcast Links and Power Requirements ?
(1) Aircraft operating in Class A airspace must have equipment installed that meets the antenna and power output requirements of Class A1, A1S, A2, A3, B1S, or B1 equipment as defined in TSO-C166b, Extended Squitter Automatic Dependent Surveillance-Broadcast (ADS-B) and Traffic Information Service-Broadcast (TIS-B) Equipment Operating on the Radio Frequency of 1090 Megahertz (MHz).
(2) Aircraft operating in airspace designated for ADS-B Out, but outside of Class A airspace, must have equipment installed that meets the antenna and output power requirements of either:
(i) Class A1, A1S, A2, A3, B1S, or B1 as defined in TSO-C166b; or
(ii) Class A1H, A1S, A2, A3, B1S, or B1 equipment as defined in TSO-C154c, Universal Access Transceiver (UAT) Automatic Dependent Surveillance-Broadcast (ADS-B) Equipment Operating on the Frequency of 978 MHz.
