I've just bought an H2AD for use in my -9A.
They use a modified Dynafocal-1 mount with a deeper top cross tube to clear the rear of the crankcase. If you specify it at the time of ordering your finish kit Vans will sent you the mount you need. I'm told the H2AD mount will suit other Dynafocal-1 engines but not the other way around - so if you're not sure what way you're going to go, perhaps order the H2AD mount anyway?
If you have a standard mount, as has been said, you can modify it locally. I'm doing just that, but taking it a step further. Through Vans, I was put in contact with the company that actually makes the -9A engine mounts and they're more than happy to pre-bend a new cross-tube for you to weld straight in. Cost is $65USD + shipping.
There's a lot of bad press about the H2AD, mainly carried over from the early days when they did do (quite) a bit of chewing through camshafts, but this has all but disappeared now Lycoming specifies a special additive in the oil - that is in many aviation oils now anyway.
This stigma means you can often get a reasonably low-time H2AD much cheaper than other -320's.
Apparently, you can get roller lifters for this engine based on Ford 351C engines as well, there's a couple of threads here on that particular mod.
You will need a cowling bump if you use the engine-driven fuel pump, otherwise run a pair of Facets. The dual-mag arrangement can be off-putting for many people, but LSE will install trigger magnets in your flywheel for $75 if you want to use their EI system.
Finally, if you ever plan to run a constant-speed prop, this engine is not for you. It has a solid crankshaft. You can use MT props or a couple of other electric ones out there, but that is significantly more expensive than using a traditional CS prop.
