I decided to build the right wing first so I didn't have to deal with the pitot tube and stall warner. I'm about to close it up, but I don't want to make my life horribly difficult later on due to lack of access.
One major concern is that I drilled two large holes (where / how big as Van's suggested in http://www.vansaircraft.com/pdf/Wing_Wiring.pdf) in each rib, but I don't have any idea what electrical gadgets I plan to install, hence I have no idea how much wire to run. Should I install large snap-bushings before I close them up, then fish the wire later? Light-weight conduit instead? I have long arms and small hands, if that helps![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Other than that, I wonder if I should have someone inspect the insides before I put on the final skins.
Anything else I should be thinking about right now?
Thank you so much!
Thank you so much!
