jc11378
Active Member
Well I have to say, the Antiplataero.com prop wrench adapter is well worth every penny of the cost.
This weekend i had to start the engine removal on out 1980 Piper Saratoga. It has one of the hardest props to remove due to the spinner mount ring is bolted to the flywheel. This causes the prop hub to be recessed deep into the spinner mount ring.
With the Antisplataero prop adapter wrench, it really made this job so much easier. This wrench should be in every aircraft owner/mechanics tool box.
I give this tool 5 out of 5 STARS
Prop Wrench
I to will say the wrench is a really handy tool to have. Made pulling and installing my prop so much easier then the old wrench I had adapted to do this with. I would recommend this tool for anyone who does not have access to a good tool of removing an instilling props. You tube video on its use is handy also. :)
