JerryG150
On other LSAs I've flown there was a small light panel indicating the position of the servo-tab. Is there an indicator light system on the screen of the Dynon180 to indicate the position so it'll be in the correct position for takeoff etc??
Indeed there is a stab trim indicator...
The calibration procedure lets you set a take-off position which is indicated by the green line.
Tony
Jerry,
You have to run thru the calibration procedure in the Dynon manual before it will show up on the display.
AND REMEMBER........
When the tab is down, that's nose up pitch trim.
I know it sounds basic, but approximately 1/2 of the airplanes I inspect have the pitch trim backwards.
