Weight, weight, and even more weight. Then there is that complexity thing. You will have to add two solenoids of some type to the brake system to relieve the pressure of the locked wheel, a sensor on each wheel, and a computer to compare the sensor speeds to each other and trigger the sensor to unlock the offending wheel. Then the program also needs to be set to let you lock the wheels at low speeds.
A little known fact about ABS auto brakes, in heavy snow and gravel, you can stop the car quicker (shorter distance) if you can lock the brakes.
Funny story time. I live on a fairly steep city street and a number of years ago some lady in a non-descript GM product tried to stop on the hill. There was about 1" of snow on the ground and she could get the car slowed down to about 2 or 3 MPH and then you could see one wheel slide. At that time, the ABS would kick in and unlock all the brakes. It was like watching an accident in slow motion. I can only assume that GM has fixed that problem since then.
