With a vertically oriented antenna, the signal will propagate from the side of the antenna in a 360 degree pattern. The signal will be weakest in the direction that the tip of the antenna is pointing (i.e., straight down and/or straight up).
With a horizontally orientated antenna the signal will radiate out from the antenna the same as the vertical antenna. However, since it is horizontal the pattern will radiate vertically. I assume that the antenna on the ground would be set horizontal, perpendicular to the runway, with the strongest signal straight down the runway. Think of a tire cut in half, standing up.
Tracy.
