After perusing the archives, I couldn't find an answer to the following as I build my canopy frame - has anyone had problems with the BOTTOM of the tip up canopy frame front skin being proud of the fuse side skin? Mine is almost 3/16" inch out on both sides. It is just the front 3-4 inches and then starts curving in matching the side skin as one proceeds aft to the side rails. I can see where I may be able to use seamers to help, but the frame looks like it may be slightly wide at this point (and too late to correct through the splice plate as all riveted, gooseneck hinges done). I thought I saw a reference where someone fluted the bow of the front frame channel, but that may destroy the nice fit with the front skin gap, where I seemed to have avoided the common bowing skin issue at the 2 and 10 o'clock positions,
I will post pics later when able if the above is not clear.
