This weekend, I installed my wings for the first time. I rolled the fuselage out onto my driveway and leveled it in pitch and roll axis. The wings were slid into their mounts and I drove in tapered wooden pegs to hold things in place. Once the pegs were in, I replaced with hardware store bolts. I discovered that a digital level can either be a curse or a blessing as it can drive you nuts as you chase down that last 1/10th of a degree! I went through the normal amount of measureing and sweating before convincing myself that it was ok to drill the rear spar. After everything was done, we took it all apart and rolled her back into the shop and installed one wing only. I will do all of the things that need to be done, then swap wings. One observation...we sure do have stubby little wings with our RV's. The thing looks like a sheet of plywood hanging off the fuselage out there ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Tinman
Tinman
