Walt
This has everything including the GHA15 radar altimeter!
That's beautiful Walt.
May I ask, for an experienced person like yourself, how many hours to do that installaton?
300 ish, most airframes require extensive rewiring, new alt with BU alt usually, all new lights, new pitot-static system, etc. etc..
Can you say where you located the GHA15? Thanks. A picture , if you have one.
Because I had a hole in aft fuselage where a previous strobe was located, that’s where I put it (I try to avoid making unnecessary holes).
In reality the change in height from a more centered location is minimal. Had a hole not been there I would have put it just forward of the pitch servo.
Looks great Walt.
Probably wish you had a small person to pull wire for you.
That has to be a PITA.
BOOMER
Behind the panel is as impressive as the front side. Perfect setup, well done Walt.
Thank you Walt.
