Stockmanreef
Section 26-11. This is for F-01484. There is a hole which is drilled out to 9/16. There are two # 30 holes on either side of this hole. Are they supposed to be dimpled? Is there a larger nut plate that goes there? Otherwise, why dimple them?
More importantly, if the dimples are not necessary, then they will be hard to undimple later.
thanks
ken
thanks
ken
It says in step 7 and in the right side detailed view of Fig 1, to final-drill them #19.
It never says to dimple them.
These three holes are intended for installation of a blade style transponder ant.
