Paul Austin
Active Member
Hi
I am just at the stage of connecting the main alt wire. I am a bit confused as to the purpose of the anl60 in the system is it to protect wire going from the alt to the firewall or the wire from the firewall to the power buss in the cockpit as it seems when connected like a lot of the ones on this site that there is still a direct route for the power direct to the battery battery and if the wire from the master relay to the power buss shorts out the full current of the battery would flow with no circuit protection. Any info would be greatly appreciated..
