Flying Scotsman
I'm building all the cross beam assemblies and such for the Andair pump, and I've run into a question...how are people dealing with the holes/platenuts on the sides? That is, the cross beam assemblies have small angle clips that have platenuts on the "inside". Fair enough...but then, since these cross beams go underneath F-782C, it seems the options are a) countersink the #8 hole in the clip, dimple F-782C and use a flush head screw, or b) somehow figure out where said hole(s) in the clip and F-782C end up on the floor stiffeners and drill them (which would be a blind drill...hole duplicator needed?) and screw all 3 pieces together.
If the former, doesn't look like there's enough material on the clip do a countersink for a #8 dimple in the F-782C, and if the former (which makes a little more sense), how are you locating the holes to drill the stiffener?
Also, are there any other tips/tricks for this out there? Seems pretty straightforward so far (except for this).![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
TIA
Steve
TIA
Steve
