pa38112
There is that old saying about "fool me once..." - I am really tired of the O-rings for my Andair gascolator. If you purchase the correct O-ring they do not fit tightly against the bowl grove, making it almost a sure thing that the O-ring will be damaged during assembly. I am tired of replacing it every year only to find that the new O-ring fits as poorly as the one I am replacing. From searching the forums I do not think I am alone with this problem. I use Fuel Lube on the O-ring, so that could be causing drag as I assemble it. Regardless, I have decided that I am going to replace it with a "proper" fitting O-ring. After {this part is re-edited after much o-ring sizing}. I have tried every conceivable size o-ring and found the a 2.5mm X 36mm is the perfect fit.
(Edit 6/25/2018 - After a year in service I had a VERY difficult time removing the glascolator bowl for my condition inspection. So hard that I was going to go back to the standard Andair o-ring, but when I installed one it was so loose that it reminded me why I started this investigation to begin with. I ended up re-installing a 2.5mm X 36mm o-ring and used fuel lube to lubricate it. I will report back next year. I would not recommend installing this o-ring without lubricant and I can't say for sure if lubricant will fix the removal issue.)
Below are photos of the Andair 2mm X 39mm and my replacement 2.5mm X 36mm. They can be purchased here: http://www.theoringstore.com/index.php?main_page=product_info&cPath=368_65_67&products_id=2776
Andair 0-ring:
![](/community/proxy.php?image=http%3A%2F%2Fi613.photobucket.com%2Falbums%2Ftt215%2FN153MC%2F025_zps3sf6mrn6.jpg&hash=fe22cbd38775e5bee8af2934e541bcf4)
2.5mm X 36mm Viton 75 O-ring:
![](/community/proxy.php?image=http%3A%2F%2Fi613.photobucket.com%2Falbums%2Ftt215%2FN153MC%2F024_zpsqejbkuab.jpg&hash=5e3f1c2f18c93c7565391ff4cb15c8a4)
Andair 0-ring:
