Scott Will
If I were to install an Andair fuel selector, would you have to replace the stock fuel valve plate F-983A?
And another simple Andair fuel valve question, if you are using an IO-360 do you need to order the duplex one with dual fittings? Also what fittings do people usually get with the Andair fuel selectors?
Thanks much in advance!
