jswareiv
Does anyone know what gauge wire to run from the Andair fuel pump? I tried to go to their website for a data sheet, but it seems down or not responding. The red wire that is there is not a normal wire we have been using. I want to run that wire up to the switch on my panel.
Also, does anyone know the accessory that goes in the bracket between the two seats? Is it just a round accessory, or is there also a USB outlet going there. Not sure what that little square part is for. I've tried two different ones and neither one fit properly and Van's doesn't have that information available yet. Trying to get all the wiring done that I can.
Thanks.
I ran a 16 AWG.
The pump typically draws about 5 amps, as I recall.
A smaller wire would have been fine. The run isn't long. You could go smaller if you have to.
:) CJ
