Hi all,
This has been discussed before, but I'm still unclear as to what exactly I need for the fuel valve to make things fit right. I ordered the Andair valve from Vans, and know I need the extension piece, but do I only need the extension "tube", or the entire "extension kit"? One's about $30 and the other is about $150 from AS. I'm assuming it's only the tube (6" to be cut down a bit), but would rather order the right stuff the first time.
If it helps, I plan on combining this with Aerosport's standard center console and a 310 Carbon Fiber panel (but not the Quad Armrest - I'm going with simple vernier controls).
Part numbers (if you have them) would be even more helpful . . .
Thanks in advance . . .
Ricik
Ricik
