T Tsabean Active Member Nov 29, 2021 #1 Looking for the type of anchor nut that holds the 1/4x20 battery hold down bolt on the rear mounted battery tray. Thanks, Tom
T Tsabean Active Member Nov 29, 2021 #3 Thanks, I found my plans and that is what is called for. Problem is the hold down bolt is a course thread, 20TPI. Can’t find any anchor nuts that size. I’ve sent a query to Van’s, hopefully they have an answer.
Laird Well Known Member Nov 29, 2021 #4 Pg 71 of the plans call out 0.25-28 x 8 bolt. 1/4-28, not 1/4-20. Not hard to find 1/4-28 x 8, but double check the height of the battery you're using to find the correct length needed.
T Tsabean Active Member Nov 30, 2021 #5 That would explain it! I’ll try and source a 1/4x28 bolt. Thanks
