I installed my engine a few days ago, but just realized that I put the washers in the wrong order at bottom Lord mounts. Plan calls out the lord washer on the engine side, while AN970 washer on the aft side. Lord washer looks slightly thicker than the AN970 washer, but I can see the lord mount still can sit flat over engine (barely though, I have Lycoming IO-360-M1B). Wondering if this will cause any long term concern due to engine vibration. I dont' worry much about AN970 being smaller than the lord washer because AN970 wash is in contact with entire flat surface of the engine mounting tab. AN970 washer is 0.109" thick. Anyone know the thickness of the lord washer? Couldn't find it anywhere, and I don't have uninstalled one to measure it.
Putting the nut and cotter pin to the bolts is a pain, only want to do it if absolutely necessary.
