Thanks for all of the responses, much appreciated. There are several things I will be looking at:
Removing the other 3 bolts and having the torque wrench checked for proper calibration. The torque wrench is brand new, of good quality, and was recently calibrated. I?d be surprise if it was that, but hoping it is that.
The bolts will be replaced. The settings were at exactly 23 in/lbs. Plans call for 20-25 in/lbs.
The one bolt may very well of had a fault in it. Not a whole lot of force was even applied to it. I?m going to send Van?s a picture of it as it was a clean snap.
Of interest, I had a direct reply by way of email from a forum member, which wasn?t posted here. I don't know if it was to offer some insight or other. I'm not quite convinced that purchasing a torque wrench to correctly set torque settings as recommended by the manufacturer is a "waste of money", even for an AN3 bolt...going by "feel" doesn't do it for me, especially when aircraft have lost tail sections in flight. Plus there are other bolts that require proper torque settings later in the build, which for me justifies the expense.
As far as the bolt being counterfeit, I don?t believe that Van?s would send such items in their kits?My father is a NDT technician and from time to time, the most well built parts at times do contain flaws, cracks, hairline fractures, etc, and until some stress or force is applied, it looks good. I hope I just had a defective one. In any event, Van?s will be made aware of it and I will post back on the conclusion from the torque wrench.
Much thanks folks!
