Please consider using steel AN fittings on fuel lines FWF..
Red cube...wires up and outlet higher than inlet to get air bubbles out..
I'm installing the red cube fuel transducer between the fuel servo and the fuel injector distributor. The red cube ports are for as AN816-6D fittings. I need to know what fitting I can use to reduce down to 1/4 inch tube hose fitting
Tom Clark
N646LC
The line from the fuel servo to the spider is #4. What you would need in this case is a fitting with 1/4" NPT to AN4 flare, which is the AN816-4-4. Aircraft Spruce sells them. As already mentioned, get the steel fittings for FWF.
Not that it does much good, since the red cube is aluminum, but it's good practice.
